Beau
- Jan 28, 2011
Strange that you get no black smoke on start up revving but you do when taking off... When the engines not under load it'll use less fuel meaning more unburnt fuel I imagine... More fuel on take off so surely less black smoke, something doesn't sound too right!
And be careful with turning up the spill control valve too much, I did that and when I revved the engine it basically ran away with it self nearly red lining it self! Had to physically block the intake to stop the engine, was a scary moment! And the mechanical pumps actually don't utilise any electronic form of fuelling, like using a spill control valve. It does have one but it's known at a stop/start solenoid as it's only used to drop and go back up to block or open the valve to start or shut the engine off. The mechanical pumps are purely mechanical (don't ask me how) and surprisingly do a good job at providing the engines with fuel. The main reason Toyota changed to the electronic pump was due to Economy, emissions and better efficiency but from what I've read you need a mechanical pump to push these engines. The electronic pump just doesn't have the capacity and strength to control and push the fuelling to the engine, especially not without a well managed ECU/Tune box in place!
