AndyCook
Going to be fitting new brake discs when they arrive,
now, I am interested to know how many people use a dial-gauge when fitting new discs to ensure disc runout is at a minimum.
ive had problems in past with a subaru when not checking this, then getting pulsing on brake pedal after around 1000miles due to disc thickness variation building up over time due to the disc runout being excessive
so do you just clean up the hub surface and slam the disc on, or check runout and rotate disc round on studs until its below manufacturers max runout allowance?
