Thanks both.
Isn’t there a gasket on the top of the tank that will need replacing when doing the job too?
its not that bad a job you have to check for tears clive!As said, there is a gasket, but on mine its thick and well stuck to the tank. The cover came off easily, so just take care not to drop any screws into the tank when its off.
You remove the access cover in the floor, then remove all hoses and cable terminals, then remove the sender unit as a whole.
Clean up the sock and check for tears, then reverse order all the above on reinstall.
Simples (I know ‘cos even I managed that one )
Folks could we have some pics?
Is this something we should all add to our 80’s?
I don’t have one but assume it’s just a physical filter to stop big bits?? Does it slow down filling the truck?
Gents thanks. A quick follow up question - is this an OEM feature or you added for extra protection for travel in other zones with iffy diesel quality? I have recently been thinking about buying a Mr Funnel from the USA but the sock seems much simpler. Cheers
