I'm with Chris....
Superglue - but stay with the products especially formulated for ABS type plastics.... whilst they are all cyanoacrylates their viscosity / cure times vary.
Something like Loctite 435 & Primer Loctite 770 would be perfect, in an industrial application, but then if you only want to repair the odd item getting hold of them in affordable quantities may be difficult.
'Loctite All Plastics' is probably the easiest superglue alternative I've used - should cost ~£6 at your local DIY store... I've just repaired a cup holder with this, and its not spilt anything yet....
