Have you got any stone chips or cracks on the screen that might warrant its replacement?
It is unlikely to be your sunroof but you can always tape it up to prove it.
If it was your sunroof you would see it in the headlining.
I had my fingers really well crossed for you Alex but I believe the only sure fire way to seal the screen is to remove it clean the glass, rubber and body and refit with sealant. NOT ARBOMAST but a proper windscreen sealer such as the butyl one I have linked to. By doing this you can control where the sealant goes, avoid drain channels (which could be blocked by old sealant) and get a uniform bead of non setting sealant in all the right places you just cannot get at with the screen in situ.
It's not a difficult job provided the screen has not been bonded to the metal. You have to go gently and release the rubber from inside on a corner and gently work along the top and edge. Be prepared to treat any rust around the metalwork before the screen goes back and you will need two people to take out, move and put the screen back as it is too unwieldy.
I've had my screen visibly drip from the rubber above the mirror due to non dealing with Arbomast (did I say to avoid this stuff?).
Not what you want to hear I know but I tried all the same remedies but only taking the screen out did the job.
