Hey, I'm new here, since learning more about my 92 1HD-T, messing around with it and going about 6 years with a cruise control system that only works some of the time - I've decided to hop onto a forum and try to figure it out (with help).
The fault occurs 90+% of the time I attempt to use cruise control, after which the ignition has to be turned off and on to make the fault go away and allow cruise to be turned on again (via the stalk) for another attempt.
The fault usually always occurs when triggering SET with the stalk, and very rarely while it is actually engaged/working and once working it typically continues to work for the duration of the trip. When it does fault, the CRUISE lamp on the dash blinks 5 times. If anyone has any idea what that code means - it would help a lot!
Cheers!
Cheers!
