Hi thanks for the replies, and thanks for the offer of a spare (I will at sone point arrange to pay you a visit Chris, I want to get all the rusty bits sorted first so it's presentable).
I have a 96 FZJ80 with aircon if it helps? Now I've been having a think on two points (this is normally very dangerous).
First off I dont really know what the inside of a heater matrix looks like, but if it's a hollow tube then is it possible for me to feed a drain*cleaner attached to a pressure washer through it or is this either impossible or could it damage it?
The other thing I'm thinking is, this started after doing a rad flush and coolant change soooo it's possible all the stuff I dislodged has ended up in there. I had the hosepipe up the thermostat housing, rear heater pipes and radiator, this was the only part I didn't do.
So is it possible to fit a coolant filter? I thought I'd have my dragons den moment when I thought of it, but it turns out that coolant filters are already a 'thing'. However they seem hard to come by, mainly off industrial vehicles.
Soooo, what would you guys think to just fitting a diesel fuel filter from a Hilux or something as a coolant filter? Is there something fundamental I'm not seeing with this plan?
Thanks for listening to my ramblings
