Should you be able to access the body mount bolts
from inside the cab?
A lot of welding has taken place on the floor pan,
and I think the bolt heads have been plated over.
If it is anything like the light duty 70's, then yes.
Peal the carpet back and you should see some black plastic caps pushed into the floor pan, above the body mounts. Pop the caps out and the bolt heads are underneath.
