inclinometer etc
Chris Green90
This is probably a question mainly for Chris cos I know he has retro fitted one of these before.
I have fitted it already and everything is running and working spot on, even worked out how to set the compass and inclinometer. Only thing that doesn't as usual is the temp.
I Know I need the temp sensor but what I really need is a detailed description of where it is to be found. You see the car that I took the pod from was a total wrecker at my local scrappy. the headlights are totally gone and I am prob gonna need to do a bit of digging to find it.
So please if anyone has an exploded diagram of a really good description of what I am looking for it would be much appriciated.
Thanks in advance Guys
Small grey plug behind / under the passenger head light. Two thin wires to it. You can't miss it. You don't need a wiring diagram. It's pretty easy to find. Just a little probe sort of thing.
The part is 03482-35010
Not sure what happened there. Try this as the part number. Must have had clumsy fingers engaged
83482?35010
