i decided to do some more on the rock sliders that i started building months and months ago.
the main reason why i didnt finish them before was because i wasnt sure whether my exhaust would still be running down the side of the sill, after my new engine went it. as this now isnt possible with the position of the new exhaust manifold, and the angle of the flange, i was ready to crack on with the sliders.
so.........................................
after taking a few measurements of my chassis, i started to cut the steel for the brackets that will clamp around my chassis, that the sliders will then mount to.
80mm x 8mm flat ive used for the brackets.
this is all the steel cut for the 2 rear mounts. (the front ones needed to be different.)
marked where i wanted my holes drilling, centre punched, then drilled the holes out to 12mm.
used some off cuts of 50mm box, and a piece of 3mm sheet steel, to give me the thickness of my chassis, +3mm to allow me to get them on and off.
i made the bottom pieces 10mm wider than where the sides would come to. this gave me 5mm each side, so i could get a decent weld down each side of the upright pieces.
welded them in place.
test fit on the chassis.
welded the other one together. so both rear brackets were now finished.
i then spent 10mins on my back under the truck thinking of how to attach the front brackets. i couldnt make them the same as the rear ones, as the chassis cross member was in the way.
so after coming up with a great idea, i made a cutting list, and cut all the steel to size.
again i clamped some 50mm box and 3mm steel in to give me the width of the chassis rail, but i also added a piece of 5mm aswell. this is because at the top of the bracket, it will need to go around a piece of 5mm steel where one of the body mounts is attached to the chassis.
welded on a 45mm long piece.
and another one on the other side.
i then fitted both of the brackets in position, and used a marker pen to mark the brackets where there was an existing hole in the body mounts on the chassis, as my new brackets will make use of this hole.
i then marked, centre punched, and drilled 2 12mm holes in some 50mm x 5mm flat steel.
all brackets finished.
i then mounted all the brackets in position on the chassis.
some pics showing the front brackets bolted in place, through the existing holes in the chassis.
had to temporarily unbolt the brake and fuel lines form the chassis to get the front drivers side bracket in place.
rear bracket on.
so both brackets bolted in position on the chassis.
so the rock sliders, that i made a few months ago, that have been sat gathering dust in the workshop.
used a hop up, and some bits of scrap wood to position the slider in place. i then used a string line around the tyres, to allow me to position the sliders in the correct place.
i decided after discussing it with Mitch, that the sliders needed to stick out almost as far as the tyres, but certainly no further, or they could be a hindrance when in deep ruts.
i was then able to measure the length of the piece of box that would connect the slider to the brackets, i also used a sliding bevel and engineers square to accurately measure the angle, that would need cutting on the end.
transferred this angle on to the saw.
and cut to length.
disconnected the batteries on the truck, and then tack welded the piece of box in place.
i then did the same for the front piece. once it was all tack welded together, i wanted to remove it so that i could get it on the bench and fully weld it all together.
in order to be able to remove it, i had to take 2 bolts out of the front radius arm, so that the arm would drop down and allow me to lower the new slider down.
i came to undo the radius arm bolts, and worryingly found them all to be only finger tight!
slider off.
on the bench ready to be fully welded.
all done.
other side next.
all tack welded together, just as it was starting to get dark.
on the bench ready for welding.
needed to finish the tube work, on the sliders.
so i drilled a hole in piece of tube on the pillar drill.
changed the drill bit for a hole saw, and using plenty of cutting fluid to keep the hole saw cool, drilled a hole through the tube.
once drilled, i transferred the tube to the main vice, and used the angle grinder to slice it in half, through the middle of the hole id just drilled.
needed a tiny bit of fettling to make it a perfect fit against the other tube.
measured, marked, and cut the tube to length. i then tapped it into position in the middle of the slider.
welded to the slider, ready to be welded to the other tube next.
did the same on the other slider, and the tube work was finished.
next, i measured and cut some pieces of steel to cap off the ends of the sliders.
i cut these pieces so that they were 3mm smaller, all the way around, than the box they are being welded to. this is so that once welded, i can grind the welds down using a flap wheel disk in the angle grinder and be left with lovely rounded corners, but still have the strength of the weld there. if i hadnt have done this they would have most likely fallen off, when i rounded the corners off.
welded, and then ground down.
did this on the other 3 ends. all finished now ready for painting.
hoping to get them painted tomorrow. decided against getting them powder coatedas i know there going to get some serious abuse, and what ever covering goes on them will most likely be come off when im driving over rocks. so with paint i can just touch them up every now and again.
