LPG vs Diesel
I was going off LPG before the current price escalations started but now
it=92s not looking too shabby at all. I=92m currently paying 50p / L for LPG and
rung at about 14mpg, taking diesel to be =A31.30 / L and assuming 28mpg on
diesel I=92m now running at about 25% lower fuel costs c.f. diesel at standard
price.
Quite impressed now.
Pete
Pete
Wait until GCHQ gets round to passing this email to No 11, who'll pass it to his boss at No 10, who'll whip up the tax on LPG ...
Christopher Bell
(not enjoying forking out the 133p/litre diesel costs down here)
________________________________________
I was going off LPG before the current price escalations started but now it's not looking too shabby at all. I'm currently paying 50p / L for LPG and rung at about 14mpg, taking diesel to be =A31.30 / L and assuming 28mpg on diesel I'm now running at about 25% lower fuel costs c.f. diesel at standard price.
Pete
Pete
| You're only jealous!! ;)
True, I've just put exactly =A3100 worth of diesel in there ... and it wasn't empty.
CB
How many miles does that give you Chris?
Pete
[mailto:[Email address removed]]
Pete
=A3100 @ 133p/litre =3D 75.2 litres =3D 16.56 gallons
In summer it does 29 mpg on long journeys, or about 27.5 pottering about/short journeys, so between 455 and 480 miles. In winter I'd be down at the low end of that range all the time (I think the diesel engine is over-cooled in our climate).
On a long trip I normally reckon on about 500 miles to an 80 litre tank-full, or 520 miles if I've been light-footed and I leave it till the little red light is really nagging at me.
I don't normally drive that fast - on the motorway I tend to set the cruise control to about 67 mph which is a tad under 2400rpm. If I up that to 70mph I lose at least 2 mpg, or maybe more, it's hard to be more precise. I guess that's not surprising: 5% more speed should reduce mpg by at least 10%.
The best I've ever had was 31.5, 32.1 and 31.1 mpg on three consecutive tanks full while on holiday in France. But that was on good diesel (it seems to like the Total Excellium stuff), in hot weather and driving in a seriously laid-back fashion on French "D" roads (top speed 50 mph).
CB
Thanks Chris, just checking my arithmetic as I've had such a pig of a day
I'm not sure that my mind can cope with even simple arithmetic any more!
About right, my tank holds 70L LPG and that gives me 220 miles or
thereabouts with a light right foot, about =A335. The big downside is the lack
of range with LPG and having to plan journeys with LPG stations in mind - OK
on French motorways but not in many other places.
Pete
down
is
What setup are you running with LPG, Pete?
A good friend of mine has Mitsubishi L200 and has run LPG since new
and swears by it. There are some very cheap petrol powered 4x4's
around right now...
Neill Watson
On 4 Jul 2008, at 12:39, Peter Browning wrote:
25%
Hi Neill
It was professionally installed soon after I bought the cruiser several
years ago. It's a single point injection (i.e. LPG goes into the inlet
manifold rather than injected into each cylinder as in multipoint injection)
setup controlled by a Leonardo management ECU.
I elected to put the tank in the load space so it takes up one rear seat
space rather than any form of underslung tank. It's a 90L volume tank which
holds 72L at capacity.
Switchover from petrol to LPG is not very satisfactory as it works on engine
rev's not time or temperature. As soon as the engine revs to 2000 rpm and
then falls back below that figure it switches over. Hence you can start the
engine and blip the throttle resulting in immediate changeover - this is not
good for the engine as both engine and LPG evaporator must reach normal
operating temperature before using LPG otherwise neat liquid (rather than
vapourised) LPG is injected resulting in uneven burning and hot-spots; this
is what eventually blew my engine. Also you need to run petrol as well as
LPG otherwise the injectors gum up and you'll eventually find that it won't
run on petrol at all without replacing the injectors. I let it warm up for 3
- 5 miles on petrol and occasionally I run a full tank of petrol with a
bottle of injector cleaner through.
There's a manual switchover switch on the dash also so that Petrol only can
be selected.
Downsides are slightly reduced power and worse MPG compared to petrol and
loss of luggage space to the tank and there are not many LPG filling
stations around. Upsides are much cheaper (I pay 50p / L for LPG), no London
Congestion Charge if you register it as an LPG converted vehicle and better
emissions quality which helps on the MOT.
If you can live with the negatives then it's highly recommended.
Pete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Aha so once again the French have the prettiest wifes, the best food
and the best fuel for ours 4x4s!
Benoit
I would agree wholeheartedly with your first point, and maybe the third.
As for the second????? ;)
Pete
