Need engine manual for VM 2.5 TD 5 cylinder (HR 588 OHV)
Errol Reid
Hi,
I am considering replacing the front crankshaft oil seal and changing the head gaskets at the same time on my bj73. Does anyone have a manual paper/pdf or knows where i might be able to find one ?
Hi Errol,
The VM specialist is called VM Diesel Specialist Ltd, at www.vmdieselspecialist.com/
They are based in Chesterfield.
I think that they, if anyone, would have at least a spec sheet with torque settings and maybe a manual.
Hope that helps
Rodger
Hi Out door Dan
Could you possibly email me your manual
I have a 1989 BJ73 250td not sure if it’s 5 or 4 cylinder?
Many thanks in advance
[email protected]
Cheers Errol. Real help.
I am still struggling with parts, my LC seems to be an 89. Euro 4x4 sell bj73 250td parts from 1/90?
not clear to me what I can order and what years have compatible parts?
Still researching...
Errol. I sent you the spanish manyal for 4 and 5 cylinders and the range rover manual for 4 cyl. Did you get them?
@Christain My research shows that 73s were made from 1985 to 1990 nor can I see any reference to upgrades during their production run so it would perhaps imply that the Euro 4x4 date is an end date.
Rodger
Rodger
Thank you Rodger. I’ll order parts from them on this basis
Mine was first registered in Spain in March 1991 by the way. Quite possible it was on of the last ones
It looks like a five cylinder. Seems nice and clean !
I have found a manual for the VM 2.5 TD its for (4) four cylinders but apparently its the same with an added cylinder.
https://www.uscars.biz/uscars/jeep-documents/manuel_atelier_moteur_vm_diesel.pdf.
Still collecting info....
Errol/Christian
The manual in the link above is for a version of the VM that differs significantly from the one in your 73.
The link below is for the 4 cylinder VM as fitted to the Range Rover Classic. The bare block, injection pump and top end are identical in every respect to the VM fitted in the 4 cyl 73.
I recommend you use this as your first point of reference, not the Jeep VM.
http://www.filedropper.com/rangerover2-4and2-5vm
The link below is for the Spanish workshop manual for both the 5 and 4 cylinder engines. Its in Spanish and has useful info for rebuilding the 5 cylinder.
http://www.filedropper.com/manualvm-esp-e4x4
Errol/Christian
I recently took delivery of a 1989 BJ73 with the 5 cylinder VM engine and was hoping someone could share the tech manuals with me. Any help would be greatly appreciated.
Having the same issue as '88 BJ73. Just imported a BJ73 from Portugal with the 5 cylinder VM engine and it is in desperate need of an overhaul before I can get it MOT'd. Scoured the web for the past week with this being the most recent thread I've found. Found the Jeep manual but if anyone is willing to share the 5 cylinder manual, that would be awesome. Thanks in advance.
4 cylinder manual (Range Rover... VM95A/HR4924HIT - Identical to engine fitted to Salvador Caetano BJ73.):
https://drive.google.com/file/d/1ans2TwRs4Mfcj5IqREmNwCEg7S-boLl-/view?usp=sharing
Spanish Workshop Manual for both 4 and 5 cylinder VM as fitted to Salvador Caetano BJ73:
https://drive.google.com/file/d/1BqVBhU5iltyuZzp1p5yiUzxIfVXJy_T9/view?usp=sharing
Part no. for replacement cylinder head for both engines (Mopar). Approx £85 from Ebay. Requires screw in injector not cantilever clamped injector. See photo below:
cyl_head by Dan
head_and_injectors by Dan
Head bolt part no. £37 off ebay:
head_bolts by Dan
