hi all,
have recently purchased a 97 plate prado import, but within a week of driving it, have noticed a really annoying grating noise coming from the rear brakes
so i bit the bullet and took the rear wheels, caliper and disc off, and discovered the retaining clip which sits ontop of the spring was resting inside the bottom of the disc, which im guessing was the annoying noise
now ive done a fair bit of work on cars, but this shoe setup seems rather awkward to work around, due to the fact the hub is covering the the whole of the shoes
normally when there is a hub in the way, there is a big hole to work through, but not on this?
so my question is, do you remove the hub (which could be hard due to the bearing) or is there an 'easy' way to fit the shoes, or have you just got to struggle around the hub?
many thanks
many thanks
