hello all
hi ed,
i hope that only applies to your part of the world with regards car parts, the weight i think is going to be positive,
right the build,
we have started to line the interior, using a 1 1/2 x 1" lathes these are not structual in any form but we took advantage of the placement we used 25mm celotex insulation, and finished using 4mm external ply, these are all glued and screwed , all the wiring is fitted into the roof space so no bother at the moment
at this point we were ready to cut out the opening for the door this is a new motor home locker door, very very expensive, which i got very very cheap it might be on the large side but will do me nicely i was fitting two doors at one stage but you lose a lot of wall space, which im planning to use for storage and other hide aways
i lifted the door about 75mm off the floor to allow for my bed , we offered the door and frame to the inside sitting on the 75mm spacer then drew around tight , then we removed and drilled 4 8mm holes, slid in 4 8mm bolts, then sat the door and frame on the outside sitting on the bolts, might seem a long way round to do things, but it worked perfectly, then we simply cut out with a jig saw
great fit, im pleased with it, i couldnt have got hold of a better door there is just enough for the interior ply to sit flush with the frame , might even get hold of some t strip to finish,
the roof were going to leave, i think we might sheet the internal roof and fix the insulation from above, then cover in a few anodised blue ally sheets, that i can buy local, in 4mt x1.5 sheets cropped to any size i need
i have to slide in one more sheet of ply for the storage, then the roof sheets , then i can close up the front, there are a few cupboards i need to fit in later, but these can go in through the door,
i have to sought out the ventilation, dont know what im going to use, sky light ? will it sit secure and stay dry on the front of the roof the bit that slopes down 45 degrees these were usually fitted horizontally on caravans and motorhomes, or do i get some kind of fixed vent, i know i have to have air passing through, just dont no what system,
still need to find a water heater, looked at the kampa geyser as chris stated looks ok, utube shows some good vids, i think i need one in a more permanent position.
any one got any experiance in solar panels, i want to buy right the first time, run a computer, phone chargers, lights, pump, fan, fridge, will fit a 12v diesel heater at some point.
ive got two gel batteries for the camper and i have three batteries in the truck, come to think of it i dont think ive put any pics up of my truck, you can catch them shortly.
later joe
