knicko
- Dec 23, 2012
Since removing my EGR system last year, I’ve found quite a lot of oil builds up in the air intake, so much so that I can’t stop oil leaking from the EGR blanking plate on the end of the inlet manifold. I have used gaskets and silicon, but still it leaks.
I’m going to take all the inlet apart again and remove the manifold, so I can clean it all again properly. This time I want to fit an oil catch can system between the crank breather on the rocker cover and the turbo, to curb problems in future.
Can anyone recommend a catch can kit that works nicely with a TD 3.0 engine variant please?
