Nick Shepherd
- Apr 3, 2010
Started up today after a few weeks sat and there is a trickle of white smoke at idle which becomes a big plume of white smoke with a hefty throttle input. The smoke smells dieselly (acrid and unpleasant, certainly not sweet)
Things checked so far:
Oil is slightly over filled, I'll take out a pint or two later.
The crankcase breather tube is smoking when removed from the air filter intake hose.
The turbo intake hose piece seems to have oil in it too.
All filters have just been changed.
My two most expensive possibilities, in ascending order of scary, seem to be the injectors are dirty (maybe some cleaner or even a tankful of biodiesel run through would help), the injector pump needs rebuilding or the turbo is knackered.
Does anyone have any diagnostic ideas for me to try out?
