It's surprising that there was almost no KE in that chain when it broke Clive. It just fell on the ground in a dead straight line. I assume it's impossible to measure how much KE you are putting in to a stretchy rope and therefore impossible to gauge when it will break. I assume that's how they work I've never heard of them before.
It's like a giant elastic band Frank, as you stretch it, you store engergy in the elastic until you're at the extreme of the elasticity of the rope, then all your pull (kinetic that is because you're moving when the rope stops stretching) is exerted on the rope plus the force of the elastic. It's quite a release of energy at that moment, enough to shift most bogged vehicles in one snatch.
A chain, on the other hand, is a direct transfer from the tow truck to the bogged truck. Even if you coil the chain and take a run at it, you'll get the sudden jolt of your kinetic energy, but it's like hitting something with a hammer, the impact is instantaneous, and then it's over. If that doesn't pull the stricken vehicle out, you have to repeat the process, and the hammer effect is very damaging to both vehicles, nothing to spread the impact shock.
Chain is very unforgiving when towing, unlike a rope.
