Not genuine karlos?
I'm not sure this problem should be viewed as a war between good and evil. IMO, the only thing that can cause the taper pin to shear off is a seized ball joint, and irrespective of manufacture, the only cause I can think of is rust in the joint.
Water can penetrate any joint, regardless, and the rest is a matter of time.
I'm convinced mine was genuine, yet 19 years old at the time of failure. I don't care how good LC's are supposed to be, at that age, consumables will be failing for one reason or another. Again JMHO.
I've decided on a mission, once a year to crack all the tapers and check the joints are moving freely. After reassembly, check them with a breaker bar for play.
