kombivan
- Oct 6, 2017
Not used vice grips but I did use hose clamps when I changed the front calipers. New hoses were supposed to go on but one of the new ones had a problem with the thread on it so the drivers side still has the original one.
Any way to test the hose without taking it off?
If its pulling to the right and thats on the right then thats possibly nit it unless the pulling occurs when you take pressure off the pedal. never use hose clamps on brake lines its a no no. One day you will hit the brakes and nothing will happem one side. it could be a problem in the back axle say left rear not engauging or left front not engauging. have you had a wheel alignment?
