Chris Green90
Not sure I thats what it called But here goes I am sure one of you will put me right. Its the Joint that bolts the rear prop to the rear diff. There seems to be alot of play in it. Should there be any at all or should it be quite loose. My gear changes seem to have been getting a little clunky recently and whilst under the truck this morning I noticed that there was about an inch of play in each direction at that joint. Is this about right? Too much?? Too little??? andd if so is the part replaceable or is it a full prop. It is on a sliding splined joint at the prop end which will come out but I have not seen it as a replacement part at for instance Milners.
Any thoughts???
Any thoughts???
