Rock sliders and tree fenders
Super Moderator
There are many designs for side protection devices and in true form I decided to add yet another. That's the thing with bespoke design, you don't always end up with what you had in mind. Well these have proven very effective so far. Given the amount of paint that has been rubbed off, they are clearly doing the business.
I started by fabricating chassis brackets. I wanted through bolts to tension them onto the chassis rails, but also to have a solid bottom end. This required accurate measurement of the width at the mounting point.
They looked like this when offered up loosely
Then I added the 50mm rock slider. This protects the underside.
They are only tacked. That's not the extent of my welding skill.
Then I got into pipe notching with gas pipe. This is very satisfying.
But there was some tricky geometry to cater for
This gave me a set that looks like this
and when fitted like this
All they needed then was a coat of paint and I was ready.
No I didn't put High Lift jacking points on them. Largely because HL jacks are really a bit useless in my view. I have a jack with the car and that is fine for changing wheels. I think that they are one of the most over rated must have 4 x4 accessories that you can get. They look cool as an ornament. But in any case, I can use the HL straight onto the sliders. If I am only changing a wheel then it works fine without special sockets. OK, I might add some later - all right?
KZJ90
Good looking tubes, but what happened your Asfir-sliders? ;) Have you sold the brackets?
AndyCook
scotland
Another thing for me to try and make....
Got myself a chop saw now, found a local steel stockholder, so need to order the materials and get practicing welding.
Chris.... can you remember the size of the box section, tubular steel and metal plates you used to make these sliders, as hard to tell from photos, and i wouldnt want to over or under engineer them...
ahh - i see one of captions says the sliders had 50mm box section - 5mm thick?
Super Moderator
Eee, err, arr - I dunno Andy. Been here two minutes and questions already. I don't know!
I shall have to have a look for you Matey, I simply cannot recall. The gas pipe (which I cut differently in the final version) is mental thickness. I cannot imagine bending that (how you'd bend that in a pipe bender I dunno. As mine is a shortie, I put three slightly less intimidating brackets on than would be found on a LWB Wildsmith product. This gave give really good strength without need to be cut from a battleship. When I do the 80 they will be a different beast, I think. I do think that the box was 5mm yes, but I have some left so will check. They have certainly been effective.
AndyCook
scotland
cheers - you are the font of Landcruiser knowledge!
i would probably just use box section for both tree fender and slider
Super Moderator
Not only that but I coach shooters too. And I couldn't help notice your avatar. Now why spend £60 on a bi pod and then hold the fore-end? Come on trooper, get that fist under the butt where it belongs ans let the bi pod do it's job!!
Yeah, box is fine., Most people generally just have one bar, but I thought I'd have a slider and a fender. No science as to the profiles that I used.
Andrew Prince
Subconscious attempt to avoid joining the "half-moon" club if the butt slips? :twisted: Not that it would prevent this happening!
[/hijack]
Super Moderator
Ahh and the principal cause of scope eye is the butt (unsupported) slipping under the armpit. Balling the fist under the butt gives the proper degree of support and squeezing and relaxing the fist gives minute elevation control and better grouping. It also allows the body to be flatter on the ground. Having the free hand supporting the stock (or actually introducing more vibrations etc) means that you cannot get your head and body down low in line with the rifle's line.
Lesson over. Back to cruisers? Or maybe a new thread.
Gav Peter
Admin will be with you shortly... Sorry - Chris... Shortly is someone else I'm thinking of ;-)
AndyCook
scotland
cheers for the shooting tip. i will try that out, not much recoil on a .22lr mind you!
Super Moderator
You are welcome to try my .300 WIn Mag anytime with 200gr round nosed. Going up this weekend. Might knock over a big one or two.
BobMurphy
scotland
Will you be in the Edinburgh area perchance ??
(I'm boat-launching at Port Edgar on Saturday morning - but not with my car).
Bob.
Super Moderator
Stranraer Bob..
Andrew Prince
Tough beasts, these British deer - that's a lot of gun to be using on bambi :twisted:
Stranraer Bob..
My old man's neck of the woods. Well, before he ventured South to the dark continent!
Super Moderator
Yes, but at 400 yards you want them to fall over not just get cross and run away you know.
Super Moderator
You're welcome. What for? That's a heck of a time delay.
Those sliders are still going strong after nearly 6 years. Save that little truck quite a beating. Of course subsequent owners managed to take care of that in many other ways.
