Evening...
So 21 hours thrown at it this weekend, Friday to today
.. few random pics not covering everything but most things
Door top done, will drop the glass out and do the inner later
Its straight its just the rubber that usually sits on the chrome has flopped down and makes it look a little curved
Got rear drum stripped, all new going in but not in yet
stripped and painted rear drum
Huge area of rust behind the land cruiser script, however i made a huge cock up
and put too much heat in and distorted the rear quarter..... nightmare... except i realised we needed another fuel filler so i took a template from the other side and cut the slot... Distortion vanished the second the panel relieved and i have way of filling second tank
Distortion
So once i had got this lower corner done
I got rear panel painted so boot can go on perminantly. LC has to stay outside so has to be secure every night
got rear tailgate seam sealed and painted
So many many hours work got the lower off cut grafted in, repaired because it had a lot of rust in it too. The rear body mount all repaired too as it was holed and all the inner arch repaired. Also stripped all the rust and crap off the frame inside this wheel arch and got that painted...
So this corner nearly done, did a little more work to the outside of the rear tailgate, you can see the new 2nd tank fuel filler which i will have to make the insides for
No filler at all just butt welded, hate the stuff ..
Mark
