- Sep 11, 2013
So got one of these to monitor the fridge when on holiday this year. Got a Mobicol 40 or something that can do both 230vac or 12vdc, different type of cooling mechanism on the different voltages.
So plugged in the 12v's and filled with beer and wine, and stuck the peanut into to monitor.
Works via Bluetooth to an app on your phone.
Comes with various mounting options as well, I used the sticky putty for the fridge.
The alerts it can give if you set the temperature levels
The quick results, and the info from the peanut.
Think it is every 30 mins below but it can get changed in the settings in the app.
So from the results on 12vdc the fridge isn't really cool enough, needs to be plugged into the inverter at least when the car is going.
Think the peanut is a useful so far.
