- Feb 2, 2013
While searching for genuine Toyota plugs i have learnt that the diesel heater light on the dash is just a reminder and is in no way actually connected to the plugs , and the temperature sensor (not sure if its the one on the intake or the one to the dash gauge?) tells the ecu to fire glow plugs so if the sensor is weak dirty or on its way out the ecu won't get the message causing starting problems much like you describe .
You know a lot more about these trucks than me mate but i figure the above is good information to share as it might help the next fella with starting issues .
