Well I installed a CB unit but I'm having trouble with the SWR reading. It is going right off the chart on every channel.
The CB is wired to a cigarette plug. The antenna is a Mini Tornado Stinger - 88cm - on a mag mount.
No matter where I put the antenna the SWR is the same.
I havent started cutting the antenna - wonder if the cause is something else before I start cutting it..
Advice?
Advice?
