With the correct fuses in the fuse box there should be no reason for a burn out. Note use of the word 'should'.
Coily phone lead is no good, only very thin and a nightmare to work with. I don't suppose there's anything off the shelf that would do it. I have some test lead wire that's gotta be 30A. If you decide its viable, I will willingly send it to you as it's been sitting in a box for years.
Wouldn't an inline fuse in each wire before the flexing part remove the fire hazard at least ?
Looking great, Oding
I'm interested to know what the stock arrangement was for the cabling from the body to each of the rear doors, and whether you have rear wipers.
Do you intend any modification to them?
My 80 has the barn or ambulance rear doors and soon after I bought it, the rear wiper on one side stopped working. Like a fool, I didn't investigate it and soon afterwards, I had a complete wiring burn-out, rear to front, including a total melt down of the fuse-box.
Obviously, I had all this repaired some 8 years ago, but this weekend, one of my rear wipers failed again, making me very anxious to find out why, from lessons learned from the past.
What had happened before was a short in the section between body and door, where the wires a continually being flexed each time the door is opened. I don't know the stock set-up with certainty, because it had been 'repaired' before I got it.
I was wondering if you had any alternative wiring methods in mind for the rear doors on your '61.
I imagine so Shayne. I still can't understand how a short in a circuit can cause such a burn-out, the fusing system should isolate any such occurrence, but in practice...
I don't have a problem with inserting additional fuses, a remote mini fuse block dedicated to the rear doors may be a viable option.
Truck looks great Oding you must be suffering mixed emotions , i can only compare it to reading a good book you want to see the end but you don't want it to finish .
With regards to the flexing wire , chaffing against each other is i assume what rubs through the insulation so glue them together with flexible sealant and shrink wrap and they can only bend as one wire .
