UK Supplied Alternator Adapter?
Roger
The alternator is showing signs of needing replacement (again! mud, water and rotating electric triangle of love).
I have the older style round plug >92 but the later alternators are £16 cheaper and can be found in bigger amps....
Does anybody know of a uk supplier for these:
http://www.ebay.co.uk/itm/111608072953?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Or (if someone can confirm the wiring diagram for me?) I could rewire straight to an oval plug but not sure which one it is:
Although to compare the two I would guess the right one at £18?
And in so doing give yourself a bit more lead to play with. They really didn't use any more cable on these than they needed.
Thanks gents - agree with cable length its "just enough".
Plug ordered.
Does anybody have a wiring diagram so I get the pins the right way around?
Plug ordered.
Is this any good Roger?
regards
Hi Dave,
That would be perfect if it were for the round and oval plugs:
I found this picture of an adapter which is a layman's way of working it out, having a wiring diagram would give me peace of mind.
Ive just read your reply to my 100 series question - do the 100 series have these 4 pin square then? Im going to order one and try it now - cheers for that.
