Ok I will embarrass myself,
i was checking the front actuator loom over as I have now eliminated everything else ( massive thank you to Karl ) TOP Man.
anyway I found that the wire to the actuator had broken off right inside the plug, so this could of been the issue me thinks, got on the phone to Karl, and arranged to pop over tomorrow to get the loom part needed. I then decided that I couldn't wait till tomorrow to find out if this defiantly was the culprit, spoke to John ( another Top man), and decided to bypass the broken wire to see if it worked, under the truck i went with my mate turning the switch and I listened for the actuator " couldn't hear anything".
Feeling depressed as it hadn't worked I stripped the offending loom wire out and then had a cup of tea. Half hour later jumped in the truck and set off nearly ending up in the hedge as my steering wouldn't turn to the right at all, I am now suicidal because I got rid of he bloody Landy because these sort of issues. Depressed and dejected called various people to help all offered advice as best they could, then to the iPad and posted " my urgent message".
My good friend Daz turned up and looked at the truck jacked the wheel up and said di******d the locker is in on the front!!!!
I had operated it and it worked I just hadn't heard it
oops !
So good news is the actuator on the front works I just felt a plonker because I was so impatient and didn't wait until tomorrow and then connected the loom, I wouldn't of had the 2 hours if trying to figure out why it weren't working.
good outcome in the end!!!!
