There should be 4 part numbers Clive. They are all different. You'll find on the rear ones there is a white or a yellow stripe across the edge of the rubber. The white one should go against the B pillar on the right side and the yellow against the left side against the B pillar. Look as you remove them, you'll see the marking. I know as I did mine yesterday.
