I picked up a 20ft boat from Falmouth last weekend and towed it to North Wales (via Bala) and probably the first time having towed a fairly decent weight ( 2700kg) over a big distance. If anyone has driven from The southwest up toward the M5 on the A30 it is pretty undulating. However once the gradient kicked above 6% the speed seemed to shut off pretty rapidly and had to drop to 3rd gear. Generally power doesn't seem to be an issue but was wondering if the lower powerband in the 12v means it struggles to sustain higher revs under load. It didn't really cause any major problem but would be curious to know if anyone has towed significantly with both engines.
I have the fuel pump mods done but did notice a lot of extra smoke so wondering am i needing to look at injectors or this just normal.
I am running 265/75/16 as well.
fuel economy was crap. Av speed 56mph. Towing a 500kg trailer down= 20mpg.
Loaded trailer home 14mpg! normally I average 30 on the motorway@60mph unladen.
