Part III
It's been a while since posting up, I've been busy working out where to get my bits from, getting cash together to carry on and generally getting my head round some of the technical aspects.
Simon Holton at Toyota has been incredibly patient and helpful with all sorts of parts queries and quotes and the parts list breaks down like this:-
Toyota
Conrod Bolts
Front crank oil seal
Front Diff oil seals x 3
Driveshaft snap rings
Injector seats and washers
Rear Quarter trim clips
Other oddments
Roughtrax
Timing belt
Tensioner
Pulley
Head Bolts
Milners
Oils
Air filter
Oil filter
Fuel Filter
AE Engine Parts (UK)
ACL BEB's
Independent Garage
Head Gasket Set
Piston Rings
As it has been a while since working on the truck and with the continued help of MrDelmonti (Ed) from the forum we cleaned up the mating surfaces of the engine block top, bottom and sump. with 1500 wet and dry, WD40, elbow grease, lots of tea and a few swear words. This is Ed and he's sitting on the Naughty Battery, he can only come down when he starts laughing at my jokes.
I needed to replace the bent conrod and even with discount, the Toyota price was still too much. I bought another partial block that still had the pistons and conrods in, the block was a known runner which had originally suffered with a knackered head and sitting in the garage of another forum member on here about 25 miles away.
I got this home and decided to pull all the pistons/conrods out and transplant into mine, after a closer look I decided to change 2 of the piston heads for my originals as mine where in better condition. The FSM talks about heating the piston heads to a certain temperature and then you can push the gudgeon pin out.
So while Mrs Trev was out I "borrowed" a saucepan and boiled the kettle, while that was boiling I removed the retaining clips holding the gudgeon pin in. You can just see in the bottom left of the picture the screwdriver prising the clip out from the hollow in the piston. If the ends of the clip are not at the hollow, use the end of a flat blade screwdriver on the end of the clip to move it along until it lines up. It takes a bit of force to get moving and be careful not to gouge any metal from the piston.
Once these are pried out, be warned they will ping for miles, I nearly got the cat twice.
So piston in saucepan and pour in the boiling water
After waiting for about 90 seconds and handling with a "borrowed" tea towel, lift the piston out and drain the hot water, then you can push the pin out really easily.
The gudgeon pins are matched to the piston heads according to the FSM, so I made sure that the correct pin got transferred with the correct piston head. Once the disassembly process was done I put the very hot pins in the sink with cold water and then put the piston head back in the saucepan to reheat and boiled up more water (the piston head doesn't need to lose too much temperature before it contracts to the point where you cant insert the pin)
So with a hot piston head and cooled gudgeon pin it was pretty easy to reassemble.
I had read a lot and seen on YouTube the need to check the piston ring end gap and file them if needed, my mate at the local garage said that they never do this and just fit the rings as they will be in spec. I decided to check anyways.
First thing I did was lube the bores with clean engine oil and squeeze the ring closed, insert into the bore to 120mm as detailed in the FSM and then use an old piston upside down to square the piston ring off.
Then using feeler gauges, check the end gap.
These pictures are not at the 120mm depth but for illustrative purposes, turns out they are all in spec and can be fitted as is, just like my mate said they would but I have peace of mind having done it myself.
The next task was to clean the piston tops with 1500 wet/dry and WD40, I still need to do the piston ring grooves but will be borrowing a piston ring tool to get the 2nd ring out.
Front axle was the next task, I thought it would be a good idea to change the oil seals and I had concerns that I might have broken the air pipe for the front difflock so wanted to check that out while it's off the truck.
Armed with these of we went
Split the casing and cleaned up the mating surfaces of old sealant.
Connected the airline and checked for leaks, all okay fortunately.
Applied new sealant
Put back together, and fit oil seals, decided to do the prop seal when its back on the truck.
After needing some advice from the forum, I replaced the injector seats and seals in the cylinder head. Seat goes into cylinder head, washer goes into seat with rounded profile to the top, then screw in injector and torque up.
Interesting that Haynes and FSM have different torque figures, Haynes say 54Nm and FSM 64Nm so I went with the FSM.
Finally torqued up the glow plugs
