Trevor
- Jul 25, 2010
Part IV
As this has been standing for best part of 9 months, the water pump and starter has seized so I decided to change these and also put in a new tensioner, pulley and timing belt. The starter I will keep, refurb and put on the spares shelf so I sourced a second hand one off Ebay to stick in for now.
Fitted the head gasket
And bolted the head up
Tightened everything up and then tried cranking the engine round with a socket and ratchet to ensure everything was right. The engine kept locking and after slipping the timing belt off we tried to moving the cam position by 180 degrees in case I had missed something when I timed everything up. You can turn the crank pulley so that all pistons are mid way in the bore which gives you the room to move the cam position without the valves fouling.
Refitted the timing belt and tensioner after using a vice to wind back the tensioner to put the pin back in. Tried cranking the engine again with the ratchet and it locked again, something was not right at all so finally decided the head needed to come off, I ordered up another set of head bolts from Roughtrax as I wasn't happy reusing the new ones I had just put in.
Once the head was off, this is what I found
The precombustion chamber had dropped out of the head while I was fitting it, no wonder I couldn't crank the engine round. After much head scratching I can only think that the overall temperature of the head was really quite warm as it had been stored in Mrs Trevs greenhouse (nice light bench area to work on) and it was carried out and put straight onto the block, I reckon this heat was enough to have made the chamber loose and the little nudges and bumps getting the head into position is what dislodged it.
The following morning I refitted it the chamber into the head using the wooden handle of a hammer and it went back in with a snug interference fit, the new head bolts had been delivered so the head went back on for the second time and now the engine cranks cleanly for it's full cycle. So don't leave your cylinder head in the Wife's Greenhouse
Next job was to put RTV sealant on the cylinder head pressure release thingymabob
Make sure the widest part is fitted on the outside of the head, if you do it the other way and you have a build up of pressure - well it's not going to do it's job.
Fitted the new rocker cover gasket and finally the cover itself
Correct orientation of the exhaust manifold gasket
After much copper grease and some gymnastics the exhaust all bolted up
Before putting the inlet manifold in position it is worth spending some time at this point sorting out the routing and fastening of the fuel pipes to the injectors, if you don't do this now then you have a lot of fiddling and swearing later on. The 2 fuel pipes nearest the fan will go over the manifold and the 2 nearest the bulkhead route over the oil filter and up through the manifold.
Take the time to clip the pipes into their respective square plastic clips, the other clip that holds all 4 pipes needs some careful manipulating.
Hold this clip horizontally and slide the pipes into the channel near the top, 2 slide in from the left and 2 from the right. Make sure they are aligned in the channels at the back and then swing downwards, you may need to get some fingers behind the pipes and squeeze with your thumbs on top until they click into place. Pick a spot where all 4 pipes are straight to put this on.
It is also worth checking and refitting all vacuum hoses at this point as it's practically impossible to get to once the inlet manifold is on.
Fitted the inlet gaskets
Then spend most of the afternoon like this
I found that removing the studs from the EGR valve allows the inlet manifold to be easily offered up to the block, then push the studs into the EGR from the bulkhead side and tighten up with fingers as much as you can (don't forget the gasket), finally put the nuts on the end of the studs and using a 12mm ratchet ring spanner tighten the nuts up until the stud starts spinning and keep going until the assembly has tightened up.
Before doing this, make sure that the fuel pipes for the rear two injectors have been routed correctly, I forgot this bit and ended up disconnecting the fuel lines from the pump and by lots of wiggling and turning I got them routed properly as I didn't want to take the inlet manifold off again, guess this what happens when I get tired and grumpy.
I still have one nightmare nut to get on the manifold but that's best left until tomorrow.
