Aftermarket aircon condensors
AndyCook
scotland
I have just been talking to "motorclimate" about air con condensors to get a price
they came up with several part nos on EPC when they called a dealer for single and dual aircon systems. i only have aircon/heating in front of vehcile, no rear passenger blowers.
he mentioned many aftermarket condensors come with screw fittings, but the toyota parts use a "PAD" connection i think he said
so if you get a cheaper aftermarket one, you might end up having to change to pipe-work and connectors at extra cost, negating the cost savings.
anyone had issues like this with these connectors?
thanks Jon - i think Ecoman got stuff there too
were there any issues with connectors? did you also need to source new o-rings
our friendly parts dealer can do a new unit for £227 which is more than autoairconparts, but i know it will fit ;)
Have you looked at the pictures of each part that show the connections and dimensions? They're pretty detailed. Mine were a perfect fit. I bought a box of o rings from them as well, Toyota o-rings come on the pipes. you can also compare the OEM parts numbers they are a replacement for.
