- Mar 1, 2010
Well the oil is guess work as even God can't tell how much is left in the system. I would guess to take the recommended oil addition for pump volume in the FWM then add a couple more. A little extra will not hurt. One could drain the pump and see if there is the correct amount in and then assume the system has full volume. If not multiply up for each component and add the total obtained. Good idea to part the middle joint enough to get the o ring over the dowels but cleaning up the grooves in that position difficult.
Chris I'm not getting on your case I'm just fascinated by these repair threads. I knew nothing about a/c until Richard and Dave were patient enough to give me all their knowledge.
