- Feb 24, 2010
Went to use the 80 today to give it a run, it would have been its second outing since returning from this years Morocco trip in September.
It's an auto so I put my foot on the brake to select D and it went to the floor
After a few pumps the pedal came back but as I pulled her down the drive and went to stop, then pedal went to the floor again
Before the Morocco trip I did a break fluid flush plus I replaced a weeping load sensing valve. The 80 did about 6,000 miles after the work with no brake problems.
There are no leaks or fluid loss anywhere so I'm guessing it's the master cylinder?
I know there are sometimes problems with the master cylinder seals following excessive pedal travel that comes with the 'old style' bleed but, how come it was fine for 6,000 miles following this?
