I have a low pedal at the moment, before Xmas as preventative maintenance I replaced everything except the ABS system module, LSV and hard lines. Despite repeated bleeding the pedal travels further than before started. When I get the time I will have another go but have spent a couple of weeks in the UK visiting friends and family, having returned work has now taken priority.
I have the Sealey bleeding system with the adaptor linked to earlier and have used it on dozens of cars and in general it is great however, it does have it's downside/s. The main problem is when trying to push fluid through vehicles with ABS, it takes quite a bit of pressure to get a decent flow, the ABS part of the system creates the restriction. The theory is fluid under pressure going in will push out all air, the reality is if there is air at the top of a pipe then the fluid can pass under the air and flow out of the nipple in the normal way, this leaves the air behind, the flow has to be quite fast to 'carry' the air bubble with it, hence when using the pedal you can give it a hard shove and the bleeding is more successful. The problem with the pressure bleeder is two fold. First, if you need to use the adaptor (LC 80 for example) then it tends to leak from the connection to the reservoir, tightening the wing nuts in an effort to stop the leak results in the adaptor distorting letting out more fluid. I made a reinforcing bar out of wood, this fits across the adaptor and gives it the rigidity it should have had designed into it in the first place. The second problem is ABS modulator valves can be damaged by high pressure bleeding, this means you are limited to the amount of pressure (and hence flow) you can apply, this WILL leave air in the system.
IMHO the pressure bleeder is great for changing fluid in an already working system, connect/pump/open nipple/close nipple move on, 15 minutes all done but, when new components are fitted pumping 'the old fashioned way' is best to get air out on our trusty (but old fashioned) steeds.
Dave
