Graham
Hi all,
I found a template for a rear sub tank for a 120 series a while back.
The space used is the space between the rear chassis rails.
the tank looks like this.
Then a filler pipe like this, welded into the side.
My rough sizes,
Sizes roughly from 1mm mild steel sheet, folded where practicable, mig'd otherwise.
The front width measurement about 1000 mm
the rear width measurement about 400 mm, (this angular accounts for the corner bracing from the chassis rails to the rear cross member)
The front to rear measurement about 700 mm
The depth (height) about 200 mm
It would need a couple of baffles welding inside to slow down the sloshing.
For now ignore the fill hole, and the vent.
Instead, I would ask this what I have to be welded into the right side shown in the image.etc and making the tank 200 mm deep, give the tank a capacity of around 180 liters, = 180 kg or there about.
Is 180 liters to much? should the depth be reduced from 200 mm (180 liters) to say 150 mm, (135 liters) or 100 mm (90 liters) ?
Is 1mm mild steel with baffles sufficient?, folded or mig'd where required?
I guess if we had more than 1 built then the cost could come down?
Who could make such a thing?
Gra
My rough sizes,
Gra
