Well, seeing as how I couldn't go out to play like you boys this weekend, I thought I would get some more work done on my now very rusty bumper. I don't like High Lifts particularly, but you can't build a bumper without points in now can you.
First I welded a tube inside, in line with the dumb irons so there is max strength. There are welded under and over plus they are plug welded through the winch plate
Then I broke though from the outside and widened the holes out to take the HL adapter. Then I made a little eyebrow to go on top which actually stops the adapter from spinning right round.
Here's the adapter in place
Then feeling creative, I decided to put my front air take off point in. As the bumper is angled, I wanted the air point to be square on, so I made this little profile to sit it on. I kinda like detail on things and this adds some, well, some detail.
Got to say, it's a fine bit of welding
The added the shroud and valve
Then it was time for tea!
