Tim the toolman
- Aug 23, 2020
Hi has anyone here changed one these before if so do you have any tips ? If you do it would be greatly appreciated mine is a 11/96 manual with 270k km on the clock
Great thanks, I am glad it can be done without pulling the radiator out, as I put a new one in Saturday and didn't really want to have to do that again!, I have a new genuine pipe coming but I couldn't have the old girl off the road that long waiting for it.I've done one on a diesel, after disconnecting the hydraulic hose banjos and hoses to the PAS reservoir, there are some hard pipe clips that bolt into the inner chassis both sides at the front, get those off. There is another bolt on the top horizontal surface of the lower front crossmember and finally split the pipe holder at the front so you can separate both pipes.
After the pipes are separated, you are looking to remove the top one first by rotating down and pulling out from the front. Its all a bit fiddly but doable, the crimps and banjos do fit through the gap above the front crossmember, do the same for the lower set. A couple of swear words will see you through.
Refitting is the opposite, feed in through the front one at a time.
I got my local agricultural place to put new hoses on with compression fittings and a spare set just in case.
Trevor, another question, would a bull bar on the front make life difficult doing this job?Great thanks, I am glad it can be done without pulling the radiator out, as I put a new one in Saturday and didn't really want to have to do that again!, I have a new genuine pipe coming but I couldn't have the old girl off the road that long waiting for it.
