johnnystrom
- Jul 27, 2012
Hi guys. The truck is now safely sealed in a container on its way to Namibia. But driving it to the docks fully loaded (full water and fuel tanks etc etc) I did notice that the rear end is sagging a fair bit. I'm wondering about a cheap fix to raise it a bit when I get to Namibia. Air bags would have been nice but are simply not in my budget. I've seen a few people have added coil springs between the chassis and leaf springs, to get some extra lift. Something like this, which uses 50mm tubing welded top and bottom to mount the springs...
What do you think? This looks simple and easier than adding leaves? I want to leave the original set up alone as much as possible, and just give the leafs some help. I also need a solution that a garage in Namibia will be able to carry out without too much expense. Just a couple of inches lift would help. Any comments much appreciated. Thanks
