lc5 d4d 2005 landcruiser part number
mark1971
Hi,
I am looking for some help please,Had a mechanic out today to look at my rear suspension.
It Has been stuck in the high position and undrivable for a month now.
He has removed the sensor and the steel bracket has snapped in two.
He is talking about welding it but i am a bit unsure. (Dont know why it has snapped does it move, has it seized i just dont know)
Would anyone know the part number for this, cost, or web sit for me to check.
Thanks for your help.
Mark
The sensor bolts to one of the upper control arms I think (I have an LC3, doesn't have one!). The control arm comes off the top of the axle and joins to the chassis. You can't buy just the bracket, it's welded to the control arm. New arm is about 120 quid. I'd let him weld it!
Hi
Do you have a diagram for the AC cooling pipes to the rear on your 2005 LC5 like mine. I am looking to source a replacement for the larger pipe running under the drivers door. I've got a rack of part numbers from Toyodiy but cant work out which one I need. Cheers Chris
I'll have a look this evening - have you tried the FSM from the 'manuals' links?? Not sure if its been fixed yet...
