Thanks Gary.
Had a busy weekend sorting our new aquarium out!
I did manage to find some time to do some more on the center console project though.
I wanted to avoid the vinyl upholstery on the top wearing through on the edges where it wraps over the edge of the ply wood, which had happened on the old one.
So my plan was to make the ply smaller than it needed to be, and ensure it had foam padding on the edges. I allowed 10mm on all 4 edges and in hindsight this was too much as the finished upholstered top is a bit smaller than I'd have liked.
But it might look OK after powdercoating and if it doesn't I've got enough materials left to make another.
OK this is what I did................................
Cut the ply to size.
Smoothed and chamfered the edges using a block plane.
The foam and grey vinyl.
The foam cut quite nicely with a straight edge and a sharp saw.
The foam is 10mm bigger than the ply to allow for the foam to wrap over the edges of the ply.
Used a glue-gun to stick the ply onto the foam.
The foam started off being 100mm thick but it would compress down a lot.
I cut a piece of vinyl and laid it under the foam.
Marked around it.
Glued the foam to the vinyl.
I could then glue and staple the vinyl in place.
I compressed the foam.
The corners are the trickiest bit and I left them till last.
Not as neat as I'd have liked but as this side wont be seen it should be OK.
The bits that will be seen.
Done!
The grey vinyl isnt a perfect match to the 70 series interior but its not bad.
Sat roughly in position.
You can see ideally the upholstered top could have been a bit wider. I will see what it looks like after powdercoating and as I mentioned above, I may make a new one for it.
Drilled through the alluminium where the screws would come through to attach the ply upholstered top.
I found some nice black screws.
And screwed it on.
Removed it ready to be stripped down and powdercoated.
I removed a piece of metal trim from the dashboard.
I will take this with me to the powdercoaters so he can try and match the colour.
I will drop it off at the powdercoaters tomorrow morning and should have it back within a few days, maybe even the same day.
The 12v sockets I've ordered should be here tomorrow, then it can all be put together and fitted.
After this I'm designing and building a trolley for my welder, then that can start coming home. I'm also designing and building an adapter for my trolley jack to enable me to lift even higher with it.
Then I need to crack on with LJ's rear suspension improvements.
I'm now seriously thinking of 3 or 4 linking the rear!
I've got a spare pair of trailing arms I can cut the end mount off to give me my 2 bottom links.
I'm quite happy to weld a mount onto my rear axle to mount a rose joint to.
Its just where the top links/A arms mount to the chassis which I want to have as a bolt on system rather than welding to my chassis which I dont want to do as I want to keep it so I can easily put LJ back to standard if/when I need to.
