ive been ridiculously busy the past week or so. to the point of getting up every day at 6am and getting home to have my dinner at 10pm.
for this reason ive not had any time to resize, upload, and post any pics. so this thread might suddenly become a bit disjointed.
oh well......................
update time.
so Saturday just gone, i drove to Karls and bought a replacement panhard rod, and then went to milners and bought a 3rd new set of front panhardrod bushes, which turned out to be super pro ones. i also got some new track rod ends, but more on that later.
i knew my panhard rod was a little bent, but it was now a bit more bent, maybe due to the ratchet strap.
old one off, and compared to the new one.
the chassis side of the old panhard rod bush, looked like this.
so 2 new sets of panhard rod bushes have been fitted, and these did initially seem to fix the death wobble.
but then it came back.
so what im now thinking is.................................
im going to fit new track rod ends, as i couldnt get it tracked when i tried, because the old ones are seized solid inside the bar, and there a little bit worn anyway. im then going to get it tracked.
im wondering whether if the tracking is a bit out, then that is causing the big heavy tyres to start to shake, and that shaking is then wearing the new bushes out, until theyve then got excessive movement in them, and then the death wobble takes over every time i drive it.
so new panhard rod fitted, i turned my attention to the leaking axle.
the axle wasnt leaking before i stripped it down and fitted the locker, but it was afterwards, despite me being very careful when pulling and pushing the half shafts in and out.
stripped it all down.
decided after removing the oil seal on the other side was a bit tricky, that id knock a quick tool up to make the job a bit easier.
this is what i came up with.
so i push it inside the seal, and then turn the 2 13mm nuts in opposite directions, which spreads the legs on the puller. once thats done i can then use a hammer to tap the other end which should pull the seal out.
worked quite well, but the seal still came out in bits.
all done.
or so i thought.
found it leaked almost immediately.
despite me doing the job properly and carefully fitting the new seal.
milners will be having the other 2 seals i brought back, and hopefully also be giving me the money back for the seal ive fitted which immediately leaked.
im going to get some genuine ones and take the milners ones back and show them that they arnt anything like the genuine ones. the milners ones are just black rubber with made in the uk stamped on them. the genuine ones have a metal ring around them.
so that was Saturday and my truck was back together.
Sunday was spent trying to revise for English exams, but i did end up speaking to my girlfriend for 5 hours on skype first.
so bank holiday monday was laning time!
the plan was to go laning and driving some south Shropshire lanes that ive not driven for a few years, as a bit of a reconnaissance trip, to see which lanes are worth including in a trip im leading in a few weeks.
drove a few lanes ive not driven before, and some that didnt look like theyve been driven for a long time.
i love this little ford on a byway.
had a load of horses aproach on one of the lanes that crosses a field.
had to quickly shut the gate once i was through, and then i had to shoe them out of the way so the other lad could get his nissan through.
this would be a bloody great lane if there wasnt an oil/gas pipe line 5ft above the lane.
motorbikes can still use it but not 4x4's
shame as theres a lovely ford at a few hundred meters past the pipe line. god knows how permission was ever granted to lay a pipe line at that height above a byway.
would be nice to go down there with a digger and dig the byway a few feet lower beneath the pipes!
this was the last pic before my camera battery died.
so unfortunately no pics of my truck being the most stuck its ever been, with a foot of water in the drivers foot well.
so my mate in the Nissan towed my truck the 30 miles to my mates house. i then went and did a carpentry job with him that wed arranged to do, and then at 10pm once wed finished working he towed my truck back to mine.
i really didnt want to go work, but couldnt turn down hundred quid cash for a few hours work.
so last night i jet washed the inside of the truck out. the joys of having no carpets, means the rubber bungs in the floor pan can be popped out and the inside of the truck hosed out!
jet washed the engine and engine bay as it was covered in a thick layer of clay, and also removed the electric fan.
so the top pulley, is bolted to the water pump and used to have the viscous fan mounted to it. the pulley below it is where the oil was dripping from.
so this morning i was out working on my truck at 6am.
i need to remove the bottom pulley to get to the oil seal behind it.
so ratchet with extension tube on, wedged against the chassis, and a quick turn of the ignition key, and the bolt was loose!
bolt off followed by alternator belts.
couldnt quite get my puller in to remove the pulley.
going to have to take the rad out to give me the room.
decided to remove the cambelt cover to inspect the belt.
all looks good and no sign of oil.
it looked like was going to be a nice day.
so decided to leave all the doors open when i went to work at 7.20am, to hopefully dry the inside out a bit.
i had to race home at dinner time to close all the doors as by now the sky was very cloudy.
good job as its been raining all afternoon.
oh well we havnt had much rain lately.
ordered a new seal from toyota today, should be here tomorrow.
so once ive fitted the new seal and done an oil change, still need to fix the death wobble and electrical problem(s).
time for a beer i think!
