No gear select
plexace
australia
Hi all. I have a 2008 lc200 sahara with no gear selection showing up on dashboard display. It has "check VSC system" also 4lo flashing and traction control is flashing. Car drives as normal. Cleared the codes but it keeps returning. Any ideas?
Thanks.
what did the codes say before you cleared them?
Where the 'd' is mine has nothing
That probably won't show all the codes, there will likely be a code logged in one of the ECUs that you can't see with the cheap tool. Try and read the codes with techstream - if it's saying check VSC there will be a code.
