Overland Spares
Hi Y'all
Hmm, England have just received another sound thrashing (in the
Rugby)... so I need cheering up...
So I come to you for your collective experience regarding spares.
As most should know I am about to embark on a trip south through Africa
in my recently acquired 1994 Land cruiser (HDJ80) with 68 000 miles on
the clock...It has brand new OME shocks and bushes so I hope the
suspension should be fine.
What spares would you recommend?
All thoughts and opinions appreciated
Best wishes
Graham.
Graham,
Don't know if there is any useful information but I once found some pdf
files on the MSF site.
Mains document site address is
http://www.msf.org/source/refbooks/
or
http://tinyurl.com/ygt6cg
Transport section
http://www.msf.org/source/refbooks/MSF_Docs/En/Catalog/K/TRA/KTRA0000toc.pdf
or
http://tinyurl.com/yhpc8h
Might give you a few ideas. Least the Lions won.
Malcolm Bagley
Stafford, UK
1975 FJ45 Pickup (In Work)
-----Original Message-----
Behalf Of Graham & Lucinda Smith
Sent: 05 November 2006 17:35
To: Land Cruiser Owners List
Subject: [ELCO] Overland Spares
Checked by AVG Free Edition.
Version: 7.1.409 / Virus Database: 268.13.28/518 - Release Date: 04/11/2006
Hi Malcolm
Thanks so much for that. I am really pleased with the Essential Drugs
PDF, this will be really useful and reassuring to me.
Thanks for thinking and replying "out of the box", because when I posted
the question I was only thinking of motor spares/recommendations. This
is great -Thanks.
Best wishes
Graham.
Malcolm Bagley wrote:
>Graham,
>or
>Transport section
>or
>Malcolm Bagley
>Stafford, UK
I was thinking more along the lines of spare valves if your tires are
tubeless, that sort of thing.
One gadget on the pages that I haven't seen before was the funnel for fuel
that had a filter to remove water, looked more like a separator but the
notes said to dispose of it when expired or something. Anyone ever used
one, any good if you have? Also said to be careful when buying fuel to make
sure it wasn't cut with water!
Have fun.
Malcolm Bagley
Stafford, UK
=A0
=A0
________________________________________
Sent: 05 November 2006 20:27
To: [Email address removed]; [Email address removed]
Subject: Re: [ELCO] Overland Spares
Hi Malcolm
Thanks so much for that. I am really pleased with the Essential Drugs PDF,
Thanks for thinking and replying "out of the box", because when I posted the
question I was only thinking of motor spares/recommendations. This is great
-Thanks.
Best wishes
Graham.
Graham,
or
Transport section
or
Malcolm Bagley
Stafford, UK
Hi Graham
Im sure the ones who have done trips will help but I would think it would
be a good idea to check and recheck every thing on the cruiser that could
let you down.
I would also replace a few things like belts, and service a lot like your
Cvs, bearings oils grease bits, and look at all the washers unerbody. If it
was me going id have to take a 40ft trailer of spares with me just in case.
Fuses and relays might be a good idea especially the head light relay which
if it fails you have no dim lights.
cheers
john 92HDJ 80 1HDT
Niall
Thanks for the that link - fascinating reading!
Their major problems all seemed to be wheel-related: tyres, cracked
wheel, bearings and brakes. There must be a moral there somewhere!
Christopher Bell
|Graham
|Check out this web site.
|www.overland-underwater.com/index.php?title=3Dbreakages
|These guys drove from UK to NZ & kept a log of all the breakages and
|spare parts they went through
|Niall
Graham
I had some problems with OME shocks on some of my trips. I don't think
taking spare shocks is worth it though - replacement shocks (although
not OME) will be available all the way through Africa.
I found most Toyota dealers in Africa to be very knowledgeable about
cruisers - they work on cruisers on a daily basis and know them inside
out...
paul
---------------------------------------------------------------------------------=0AThis e-mail message and its attachments are subject to the disclaimer published at the following website of Deloitte: =0Ahttp://www.deloitte.com/nl/disclaimer
Christopher
Re - Thanks for the that link
It's intreresting when you cross check their spare part list - the
majority of the stuff they brought - they didn't need.
But hindsight is great!
Niall
Thanks Niall
I see they even have a Excel spreadsheet with their spares list on it!!!
How organised.
cheers
Graham.
Niall Sommers wrote:
Graham
Organized crew alright - handy when you have 2 similar vehicles
Apart from spares
What are you planning on doing re vehicle prep - mechanically
BEB's?
Injectors & injector pump?
Fuel, water pump?
Alternator?
CV's?
Niall
1995 HDJ80 in need of overland prep
Sod's law says that if you don't take it you'll need it!
They also implied that they were pretty heavily loaded and were
traversing awful terrain, which explained why they were suffering
drivetrain problems. I wonder if the weight of the extra kit actually
caused more problems than it (might have) solved? Certainly the little
I have read about expedition planning always seems to conclude "keep the
weight down".
I suspect a lot of grit got into the brakes and the wheel bearings, and
obeying the Toyota injunction to "strip and repack" the wheel bearings
after wading just become a counsel of perfection.
I *think* they got the maintenance schedule spreadsheet from the Toyota
Gibraltar website, albeit hacked about a bit.
CB
|Niall
Not much really.
New tyres, new bushes, new suspension (OME 2.5 inch lift).
The vehicle is 12 years old, but had only done 66 000 miles when I
bought it a month ago.
It is in mint (as new - really, it is hard to believe but if you saw it
you would know what I mean) condition, so I am hoping that with a gentle
driving style I shouldn't run into problems, and if I do the Toyota
garage will be more knowledgeable and more experienced than my local
Toyota. ;-)
I am about to arrange an oil analysis with a view to getting some data
regarding wear in the engine as this should warn me of impending
doom..., but I dare hope that the low mileage and the care the previous
owner gave this vehicle I hope all should be well.
Any recommendations will be appreciated
Graham.
Hi Graham
Just a thought one of many but if you have an OME lift to compensate for
bigger wheels /tyres what happens if your OME fails in some way. Also I
remember something about the normal size wheels to get a good supply of
tyres are the 15inch ones.
It would also seem to rule out the SS exhaust as these are supposed to be
hard to get fixed.
cheers
john 92HDJ 80 1HDT
Hi Chris
My thoughts too.
This is one of the reasons I am taking a trailer as this then puts the
total weight across 3 axles rather than 2.
Graham.
Christopher Bell wrote:
Updated EPC
--------------Boundary-00=_B56BJDU1VA4000000000
Content-Type: Text/Plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Who can help sending to me an updated EPC data for japanese car.=0D
The one Julian sent to me (long ago) ends up for LC up to june 1998 and my
car =0D
is Feb 99 (VIN no KG-HDJ101K-RNPGZ-G).=0D
=0D
Thanking in advance,=0D
=0D
Michel.=0D
=0D
=0D
Content-Type: Text/HTML;
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Diso-8859-1">
<META content=3D"IncrediMail 1.0" name=3DGENERATOR>
<STYLE>=0Av:* {behavior:url (#default#vml);}=0A</STYLE>
<style>v:* {
=09BEHAVIOR: url (#default#vml)
</style></HEAD>
<BODY style=3D"BACKGROUND-POSITION: left top; SCROLLBAR-FACE-COLOR: #c6d7ff; FONT-SIZE: 12pt; MARGIN: 0px 10px 10px; SCROLLBAR-HIGHLIGHT-COLOR: #ffffff; SCROLLBAR-SHADOW-COLOR: #ffffff; COLOR: #010158; SCROLLBAR-3DLIGHT-COLOR: #7b9ed6; SCROLLBAR-ARROW-COLOR: #4a6184; BACKGROUND-REPEAT: repeat; FONT-FAMILY: Arial; SCROLLBAR-DARKSHADOW-COLOR: #bebebe" text=3D#010158 vLink=3D#0000ff aLink=3D#0000ff link=3D#0000ff bgColor=3D#f3eded background=3Dcid:E4F63209-2369-4D66-8F52-E24E00AF463B scroll=3Dyes SIGCOLOR=3D"11031552">
<TABLE id=3DINCREDIMAINTABLE cellSpacing=3D0 cellPadding=3D2 width=3D"100%" border=3D0>
<TBODY>
<TR>
<TD id=3DINCREDITEXTREGION style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 0px; FONT-SIZE: 12pt; PADDING-BOTTOM: 0px; PADDING-TOP: 0px" vAlign=3Dtop width=3D"100%">
<DIV> Who can help sending to me an updated EPC data for japanese car.</DIV>
<DIV>The one Julian sent to me (long ago) ends up for LC up to june 1998 and my car </DIV>
<DIV>is Feb 99 (VIN no KG-HDJ101K-RNPGZ-G).</DIV>
<DIV> </DIV>
<DIV>Thanking in advance,</DIV>
<DIV> </DIV>
<DIV>Michel.</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV></TD></TR>
<TR>
<TD id=3DINCREDIFOOTER width=3D"100%">
<TABLE cellSpacing=3D0 cellPadding=3D0 width=3D"100%">
<TBODY>
<TR>
<TD width=3D"100%"></TD>
<TD id=3DINCREDISOUND vAlign=3Dbottom align=3Dmiddle></TD>
<TD id=3DINCREDIANIM vAlign=3Dbottom align=3Dmiddle></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></BODY></HTML>
--------------Boundary-00=_B56BJDU1VA4000000000--
Graham
Re: 3 axles rather than 2.
You should have seen the trailers at Billing!!
5 star accommodation - deep pile carpets, solar shower, water bed
(optioonal), american style fridge freezer, kitchen sink, the lot!
What of the draw backs on using a trailer - compromised off road
ability?, Increased fuel consumption? , more tyres to burst & anothyer
axel to maintain?
Niall
Graham
No recomendations I'm afraid - I'm still trying to decide what I'm
going to get done
Would do the timing belt anyway - as for the BeB's - tough one to call
- one of those for the peace of mind
Niall
Hi Niall
True on the extra axle to maintain, but if you get the right stuff, then
you are less likely to have problems.
I'm not sure about reduced off-road capability with the DW Lynx.. it is
an awesome piece of work. Here is their website ( the photos are pretty
poor) and I intend to send in some decent ones with this thing showing
its true capability.
http://www.desert-wolf.co.za/
Mine is the Lynx model - it even carries 85L of fuel... what a kind
trailer!!! :)
Graham
Re fancy trailer......
Thats a nice trailer!
Prefer the Billing version with the Jacouzzi, draft beer cooler and ice
machine!!
Niallo
