Re- Wet Floor Passenger Side!!!
Hy All,
Many thanks for the replies.
As yet, it hasn't stopped raining long enough for me to check out where the
water is coming from, but I feel sure it is coming from the sunroof.
Only other place could be somwhere under the front cowel as John B.
suggests (no trace of moisture in the back at all, (and the drain holes in
the rear sliders seem to be clear).
Also, I have noticed water draining from the front vents thro a pipe which
is obviously for this purpose which exits in the l.h.s. of the engine bay.
Julian, do you know if there are more drain holes in the rear corners of
the sunroof ?
Mik Kenney, (Cruisermik).
T.L.C.A. Member.
82 FJ 40 'Swagman'
97 80 1HD FT. 'Abe'
Hi Mik.,
I don't think there are, but worth checking.
Mobile: 07971 540362
