- May 26, 2014
Do you run over yourself on a regular basis shane?
Don't confuse wet dreams with something that's w#$k!As you know I'm up before the sun so I'm looking for things to do while your still having wet dreams about my 90
Steering wheel off to realign it this morning and later today having run myself over I thought I may as well check while I'm under there that it was just the exhaust I heard knocking .
What did you have the bonnet up for when we arrived home tonight , did you really overheat the brakes that much on today's gentle ramble
All the thanks goes to the others for their help and patience. At the moment I have to pump the break to get it to do anything so the drive home was interesting. Unfortunately the memory card filled up just before the steep decent with the tight hair pins.Ooh bugger, well done Nick for getting it back and to Shayne for not taking the piss at all!!
Sounds like a great crack
I did try sticking it in park but it wasn't having it. Same as going down a hill and moving from 2nd to L was allright if the speeds were matched. If not it just stayed in 2nd.Good videos Nick, if in an emergency with no brakes as you have/had. Bang the autobox into reverse or park and it will stop for sure! If it's a tossup between damaging the bodywork on 2 trucks. If not going too fast the autobox will take it, at least the autobox on my hilux surf used to take it at 40mph years ago, the tyres used to smoke really well!! Lol
Two by the look of it. Chas has seen enough and nick is posing for the camara again..View attachment 132222 How many 80 drivers does it take to undo 4 bolts
