- May 20, 2010
When we went out playing in the snow the other night i had a misshap where my truck came off the road in the ice at fairly low speed and going in a straight line.
Since then ive been thinking i have a prob with the front end. It is getting worse.
Today i lifted it with the fortruck and had a good look under it. Felt like a little play in the n/s wheelbearing so i tightend it and the play was still there. Turned out to be a little play in the top and bottom bearings on the hub.
I still kept looking. I also noticed that i have some play on the ball joint that conects onto the steering box. Only slightly but it is there.
On the way home i was expecting it to be better, but its not. It seems like a wheel is going to fall off over 40mph.
Tomoz i will change the rod that connects to the steering box and try to get rid of the play.
Anyone had simlar issues on a 80 could steering box be past it?
Thanks karl
Thanks karl
