- Mar 1, 2010
Changed one rear light, the exhaust down pipe and fixed the rear number plate light. Yes it is MOT time!!
Are toyo nuts&bolts made of cheese?
Damn i don't think i'm doing this right,and yes i did spray lot's of Wd40.
The casing is not very tough, once they are seized you will be lucky to get them out in one piece, I ended up putting new ones on ... iirc when the dust seal is off the business end of the sensor should be exposed so you might be able to drive it out with a soft drift.Any tips on removing a "stuck" abs sensor...yes I have undone the bolt at rear but it wont budge.
I have the lovely task of drivers side wheel bearing to do for the first time and a brake fluid flush...yay I cant wait to go out in this weather...I wish I had a garage to work in sometimes.
