nivapilot
- Apr 6, 2011
Hi all
My HDJ 81, of 1991 vintage has finally been nailed together, and it doesn't want to start....
I have the 12/24volt changeover switching relay....When I hit the key, all I get is a buzzing from the changeover relay..
Now if I put an earth cable from the secondary battery to the engine, it fires up as it should, but then only rev to 1600rpm.
Only thing I can put my finger on at the moment, is the kickdown cable is jammed in the open position.....would this be part of the revving problem?
And is the 12/24 volt changeover relay goosed?
Any help will be fully appreciated.
